27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
What would cause flickering and no blacklight.
I recently purchased a known “non-working” thunderbolt display.
When plugged in, the computer recognizes the display and is able to use speakers, camera, and USB ports of display.
When display is connected the backlight appears to be not powering on. On some occasions it flickers or may show output properly for a brief period. However, the backlight will then turn off. The video signal or power doesn’t drop off nor disconnects from the MacBook Pro.
Can I narrow this down to a logic board issue or power board issue. I have reseated connectors on the board multiple times with no luck and also tried another thunderbolt cable to the display.
I should mention that a picture is still visible when holding a bright light up to the display. and responds with mouse movement and other inputs. Not a frozen picture.
Update (11/24/2018)
@danj I replaced the Logic board and am having the same issue… Would it more likely be the power-supply? or LCD itself?
You’ve localized the issue to the backlight logic within the display from what you’ve stated here.
I’m suspecting the LED driver chip or its support logic has an issue. If you look at Step12 in the Apple Thunderbolt Display Teardown you’ll see the black outlined chip is the LED driver.
If you need it here’s the logic board: 27" Cinema Display Logic Board, Apple P/N 661-6060
Do you have a link to something within the Unites States? Thanks!
Here's one I found 820-2997-A 639-1575 661-6060 THUNDERBOLT DISPLAY 27 820-2997 639-1575 A1407 LOGIC BOARD. I have no history with them so do be careful.
Added an update. Hope you can look at soon
huntertrainboy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 461
