A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
which adhesive tape to use for SSD replacement?
Hi,
I want to upgrade my 128Gb SSD but there is a black protection tape over it. I’d like to use a new tape when I replace my old SSD with the new 1T SSD…
I saw that the original tape is a multi layer one.
So what do you think ? which tape should I use ? polymide ?
Thanks.
Polymide tape should be fine.
If your careful you can lift off and reuse the original tape. It helps protect the connections under it.
Tesa tape is quite fine for this task too.
@ajcooke01 - Sorry no, this is where a single sided tape is needed not a double sided.
Look at Step 10 here MacBook Pro 13" Function Keys Late 2016 Teardown
Hi did you find the right tape for the job? I having difficulty finding it myself.
alain crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 455
