Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
USB C connector works one side only
I have a problem similar to this one - iPhone 5 only charging on one side?, but with MacBook 12” 2017. One morning I found it completely dead, even though it was plugged all night and I do not usually discharge more than 80% anyway.
After spending a couple of hours attempting to resurrect the device, it finally started charging. When I opened the lid the battery was completely dead, i.e. 0%. I charged it completely and then decided to do SMC reset. I had bad luck again. After shutdown it won’t boot again, even though the device was fully charged.
After another hour of pressing various buttons it finally booted. Just in case, I did SMC and NVRAM reset, but after final reboot it stopped charging again. Another useless hour and I realized that it’s USB-C port works only one side. I.e., similar to micro USB connector, I need to plug devices in with one specific side. If I rotate it 180 degrees it will not work. Everything works fine - USB devices like flash reader, Display Port, HDMI, charging, but only on one side. If I turn it 180 degrees, it does not connect.
I tried to look inside the connector and it looks pretty normal - no bent pins or anything I could see. I am thinking about cleaning the pins with some solvent, but not sure which one to use. Could you suggest if this can be a hardware, i.e. - controller issue or more likely an oxidized pin?
I would start off replacing it here’s the IFIXIT guide: Retina MacBook 2017 USB-C Port Replacement and the needed part MacBook 12" Retina (Early 2016-2017) USB-C Port Assembly
crwdns2886500:0Replace a damaged or corroded USB-C port and the flex cable that attaches it to the logic board in an early 2016 or 2017 model 12" Retina MacBook.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$99.99
Aleksey crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,354
