Battery not charging fully
Hello,
My faithful MacBook Core 2 Duo is having battery problems. It will not charge all the way (stops at 84%). The battery is brand new and it is from a well known computer shop here in Colorado, so its not willy-nilly bought on eBay or Amazon. I tried different power adapters, T-Shaped MagSafe to L-Shaped MagSafe to then MagsSafe 2 to MagSafe converter. I also did a SMC reset but to no avail. My guess is it might just be a faulty battery because I have worked on this exact same computer (white model but I don’t know how that makes a difference) with a similar problem. I attached a screenshot of Coconut Battery for you guys to examine.
Ideas?
CoconutBattery shows the battery is under charge Charging with 24.3 Watts so it just maybe you’re rushing things. It does take a good 12 - 16 hours to fully charge a new battery.
You may want to review the MagSafe connections to make sure the contacts are clean and the insulating block is not melted.
@danj this has been going on for at least a month now and I have left the charger in for days on end. The contacts are as clean as you can get them so thats not the problem. I knew about this already but thank you for taking the time to answer this. Is there anything else I could do?
Well, I guess you’ll need to try another battery.
@danj okay thanks so much for trying anyway. :-)
[deleted] crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 59
