A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Why a certain website is freezing on loading the page?
I check if the problem is present on a different computer , and from the same router machine. And there is no problem. So the router is not blocked. It must be an IP related blockage. Thank you. Also... I suspected maybe is a special dedicated virus for blocking a website on a specific IP? I scanned my computer with an AV (antivirus) Malwarebytes and nothing is found.
is it only one website? or do a bunch of websites not work? if it's only one what is the specific website?
hi, its a NSFW type of website and there are a couple of them having the same symptom (loading partially or not at all).
Are you using any ad blockers on your browser or anti-virus on computer? They may interfere with the websites and cause issues like that.
I found the problem - It was from DNS.
Now, I have further problem. In DNS setting , there are 2 options. If I set the first option : "obtain DNS server address automatically", after some time (not immediately after I close and reopen it) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I read that the last number over 30 it means security for childrens ,etc.
I have click on "Advanced" button in the same window with DNS options, I go to DNS tab, and there I could see and delete the adress. When I delete it from there, in the firts DNS options, automatically switched to "obtain DNS server address automatically".
----------->part1
----------->part2
The problem is that, again, after some time (not immediately after I close and reopen all these settings) the option switch to 172.98.193.42 in the other option : "use the following dns server addresses". I don't know what is triggering the option to switch back. My impression/guess is that is commuted when I access these types of websites. I didn't made the test yet to be certain of the cause.
Please advice, where could be the main trigger?
Thank you!
Hello nice to meet you, have you tried clearing your browser’s cache and cookies? Sometimes your browser will store old code and try to re-use it when requesting a website you have been to before. Make sure to clear all of the cache, including: history, cookies, and cached images and files. Make sure you clear the whole history and not just the last 7 days. Hope this helps, talk to you soon
It sounds like a background running service or process is monitoring your DNS settings and changing them for you. It could also be a group policy set by the domain server. You have to figure out what is changing your DNS settings by investigating the services you have running.
oh, thank you. I will do that.
teodoric8 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 193
