The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Passenger windows switches don't roll down or up my windows?
All passenger windows switches won't roll down or up only drivers side can make them go up or down??
While rolling either down or up and one of the passengers switch gets pushed it stops the window…?
The whole passager side won't lock or the window won't go up. Is it the fuse and what color is
I’m having the same problem. But only my drivers window will go down. None of the other will go down from any switch. I have a 2003 dodge ram 1500.
Hi @ Norman Tate,
It won’t be the fuse.
Here’s the 2005 Dodge Ram wiring diagram (you didn’t state your specific year model but this is within the range selected on this page).
In Sect.8W-60 it shows the the power windows circuits for both the driver and passenger sides and they are both powered by the same fuse (IPM fuse #9) and the Power Window circuit breaker. (see also 8W-13-24)
In Sect.8W-61-3 it shows the door locks are fed by IPM fuse #28.
You would need to need to check the wiring through the driver side door lock/window switch control module to see if it was OK as the power for the passenger side comes through it.
Hopefully this is of some help
Could be the window lock switch “WDO LOCK”
It could be faulty or even simply pressed without you knowing.
I hope this helps.
If the window lock is not the problem, check your wiring where it goes from the body to the driver’s door. There is a wire from the driver’s window switch to the rest of the switches in that harness. Many times I have found that wire broken or shorted.
Vettel seb crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,676
