power cord small pin loose
power cord small pin loose; replacement of power cord did not correct
if you mean the pin in the socket of the actual laptop then a new charger wont fix it, it will probably need a new charge port
can a new charge port be installed by a layperson?
should be easy enough i dont know if theres a guide on here for it
Did this work?
Take off the back cover by removing the small Philips screws and gently pry off the back. Check the power connector, there are plastic tabs that hold it tight to the side of the case. They break easy so you need to tape it down with electrical tape or glue it in place.
The port is going to be loose, if you look at the port internally. It is not actually attached to anything inside and is held in by a clip, this is what causes it to be wobbly
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,159
crwdns2944067:05crwdne2944067:0
@revmah provide the image of the pin
crwdns2934271:0crwdnd2934271:0 Amily Grey crwdne2934271:0
I have the same problem. How do I open the Chromebook? Thank you.
crwdns2934271:0crwdnd2934271:0 Edward Gilmore crwdne2934271:0
Same here. I had it for less than a year and a new power cord doesn't fix it. I had to hold it in with my knees pushing it in all I can type. I say this is a waste of money because it was cheaply made and cannot be fixed. Will never buy again.
crwdns2934271:0crwdnd2934271:0 Nancy Jean Mills crwdne2934271:0
Nice to know I’m not alone. Still no fix.
crwdns2934271:0crwdnd2934271:0 RevMAH crwdne2934271:0
For this model, you can buy and replace the charge port easily (assuming availability) since it's a cable based jack, not a soldered on jack.
EDIT: Label for the charge port has P4GCR on it. Typing P4GCR cable into a search engine will yield results.
crwdns2934271:0crwdnd2934271:0 infiniti25 crwdne2934271:0
