AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
My MacBook won’t turn on
My MacBook won’t turn on and not charging I plug my charger it blinking green / orange what I do??
Please give us the details of your system.
Have you spilled and water near it?
Which MacBook is it? If you don't know look on the back and plug the serial number in here and it will tell you:
https://everymac.com/ultimate-mac-lookup...
It sounds like it is charging or trying to, let it charge for several hours. What is the history on this machine?
I would try an SMC reset first. Depend on your system but should be able to look up instructions for that fairly easily. If no luck with that try a different charger/battery.
He says it won’t turn on
S͛H͛R͛E͛Y͛A͛S͛ Patel crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 88
