Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
crwdns2934591:090crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Can a broken mounting peg on an analog stick be repaired?
The right analog stick was non-functioning. Upon disassembly, I found the mounting peg for the stick to be broken in two. The base of the peg still appears to function, but can the two pieces be screwed and glued? I think a replacement would be a better option, but how? This controller was bought "modded" for rapid-fire for $60, so the replacement cost is higher than a regular wireless controller. Any ideas?
crwdns2942205:01crwdne2942205:0
Depending on the thickness of the plastic you may be able to drill holes in either part and put a metal rod/pin etc use modelmakers glue to strengthen bond? I need to see it for myself to answer properly but this has worked in the past... You need a very fine drill bit..
With out seeing pictures I can't tell you about gluing it. But I believe this is the replacement part you are looking for here.
crwdns2942205:01crwdne2942205:0:
Sounds like a cheap part and less hassle than my idea!
marty crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,282
