Mac Mini dead. Fan just keeps quarter spinning ‘pulsing’
Hi. Just wondering if anyone knew what might be the issue here. PSU is fine so it looks to be a logic board issue, but I’m not sure if it’s something than could be fixed.
When I attach the power cord, the fan does a quick spin then stops, then a quick spin again, then stops, and it just keeps doing this. This is without touching the power button. It’s looks like something is failing even before it can be in a state to be turned on.
There are some places that do logic board repairs, but maybe someone has an idea what the issue may be, as I’m a little concerned leaving my Mac mini with someone for several days with 2 drives full of all my personal stuff.
It’s a Mac Mini Late 2012 2.6GHz i7 (A1347)
Thank you,
Keith
Update (07/14/2018)
Someone had a look, but can’t do repairs at a logic board level. Initial diagnosis, “Sadly it is the logic board and not the power supply. I don’t have a schematic for the board so can’t confirm the issue but one-wire communication for power on is working but the processor is not providing the start-up logic.”
Took it to Apple Genius Bar
they said it needs a new logic board = £337
as the MacMini is less than 6 years old (5years 10months) I asked it they would fix it for free, under consumer law (worth a try!)
Genius had a quick chat with store manager. They approved and replaced the logic board for free.
I was expecting a bit of a fight, but there you go. Well done Apple :-)
While IFIXIT appears to be out of stock, here’s the needed logic board: Mac mini A1347 (Late 2012) 2.5 GHz Logic Board
crwdns2886500:0Replace a 2.5 GHz Core i5 logic board (motherboard) compatible with the Mac mini A1347 Late 2012 model. Fix processing issues like unexpected shutdowns, reboots or water damage.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$299.99
Thanks Dan.
So it sounds like I need a new logic board, rather than someone being able to repair this ?
Thanks for the link. Mine is the upgraded i7 CPU however.
Someone could repair it, but they would charge around the same to desolder a component and solder a replacement component. I suggest purchasing a new logic board and keeping the non-functioning logic board in an anti-static bag if you ever decide to have a professional fix it for you.
It might not even be worth it if a lot of components on the logic board are dead or not working correctly.
I agree with Macario, it tends too be about the same cost and this is quicker.
Thanks everyone.
I just can’t seem to find the logic board with the same i7 CPU that I have.
keith crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,375
