I have a coloured line down the middle of my screen, can I fix it?
A thin green line has appeared down the middle of my Macbook LCD screen that is about 2 pixels wide. Is it possible to fix it or does the screen need to be replaced?
crwdns2889612:0crwdne2889612:0 13
crwdns2944067:08crwdne2944067:0
I have the same problem except mine is a red line and is on the right side of the screen.
Mine is on a Windows and the clolour changes depending on what I'm doing on the screen. EXAMPLE: if I was using an application that was white in the area where the line is, the line would go white. And if it was on my black desktop, the line would go green and sometimes blue.
My thin vertical red line only appears on videos, like on YouTube, or like if Bing has a video background it shows up there also. Any ideas ?
I the same problem but the color of the screen is full red how i can fix this? please help.
I have that problem also but my line runs half way down the middle and it is a brown line. My tv is a Dynex
crwdns2933315:08crwdne2933315:0
I agree with mjuergens but if possible, it would be worth testing on an external monitor to ensure that this is actually the case.
In the case that the line appears on the external monitor it could be a graphics chip issue which would mean a logicboard replacement or maybe a graphics chip "reflow".
If not then you can replace just the LCD as per instructions on iFixit and source your LCD from the store or from somewhere like eBay.
TIP: When mounting the LCD into the macbook top lid ensure you wear latex gloves.
crwdns2889612:0crwdne2889612:0 8
The problem is it's a line of dead pixels. The only way to resolve it is to have the screen replaced. Some people have tried apps that flash random colors and they claim if you have leave it running long enough it will fix it. My years of experience tell me otherwise.
Are you sure they are dead, they are all green?
There are 3 sub-pixels ( Red, Green, Blue ) for each pixel. If the transistor that controls the pixel is not receiving power, it may only be passing light at that point. In your case, they are always green.
If you just don't care if it can get worse you can try to dissasemble the metal frame from the screen, not from the laptop but the screen itself.
First you can, with some care, try to press all around then edges of the screen.
If you are more desperate in some screens (I never did it on a Mac) you can clean the rubber that makes the contact between the glass and the board, but you need to completly dissasemble the screen.
What happens is that most of the times a complete line failing is a bad contact in one point and there is no power going to the line.
Of corse if you brake the screen you can end up with the same effect and this wont solve anything.
The issue is mostly likely with a bad LCD screen that needs to be replaced. Connecting a laptop to an external LCD screen doesn't always give you an accurate diagnosis for motherboard issues since the video output from the motherboard to the LCD screen and the external monitor port are often not the same.
Well that happened to me, but mine's not a macbook. What i did was try to bend the screen. It worked fine, until i touched the screen again. I just kept doing that until it stopped working. :) hope it helps
i love you! My screen had these pixels running down the middle of the monitor and I bent my laptop screen and now there isnt the bugged pixels. I am so releaved, now I dont have to replace my laptop screen ty ty ty!
I fixed two green lines on a macbook A1342 by pushing hard at the bottom of the screen. thanks
Thanks Man it WORKED for me too
Pushing the bottom of the screen fixed it for me.
I have the same problem with my mac book pro,it used to appear at the lower part only like 1 inch, and I have been looking for solusion for a while, and didn't know what to do so I ignored it .. yesterday it was a little bit slow so I restarted it and the entire screen had lines like if it was broken and the dead pixels are every where !! I freaked out I think I am taking it to a workshop
Though I still think it is a manufactory mistake because my laptop is new and I took care of it
so what can one do to fix it...
Sadly, its time for a new display assembly.
i only get the green verical line on the videos on using firefox. iyt does not appesar when using cgromw.
AussieMac crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 104,436
