MacBook No battery Detection
Okay so first of all I never had any issues with the MacBook at all!
I put Windows on the system because everything I wanted to do could not be done with a mac OS-10. So then, I wanted to switch back to Mac OS-10 which I did.
I ran into a problem where the battery was not being detected at all! I fixed the issue for about 5 minutes and then it went back to not being detected with the X where the battery should be and it saying 0%.
I tried a SMC Reset and nothing, still I got it working again and again it was only for 5 minutes and I haven't been able to get it back working again
I don't think it’s the logic board, charger, or battery seeing that it was working on and off. When I hold the power button and remove the battery and keep holding for 10 seconds then putting the battery back in the system it then comes on without having to be plugged in but the fan is on and still no battery detection.
I think its something that's not installed or something from me switching the OS so many times.
When its connected to power cable the light on the MacBook blinks 5 times before it comes on.
Can anyone help?
I've tried everything, like I said it’s not the battery or power cable or the logic board (I think) because it was working twice for 5 minutes...
Its very annoying and sorry this post is a mess its 2 o'clock and I've been up all day working on this thing and nothing.
I also have 3 other battery's and it’s the same with them nothing works
With the Power Cable Connected
Without the Power Cable Connected
Let double check a few things. Install this gem of an App: CoconutBattery Mark your batteries so you know which is which (A, B, C...) Now with the A battery installed take a screen snapshot of the main window so we can see what CoconutBattery is telling us about your system & battery. You'll want to two two tests one with the battery alone and the other when the charger is plugged in and paste them here for us to see. If you want to you can also do the other batteries as well just make sure you keep track which is which when you paste them here. Adding images to an existing question
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
Dan there you go I posted pictures of what CoconutBattery says
crwdns2934271:0crwdnd2934271:0 Dwight crwdne2934271:0
I'm trying to download a lower verison of mac os x to try the battery updater seeing it says i need leopard 10.5.6 or tiger 10.4.11 and its on the usb and when i start up holding option it dosen't show the usb any reason why?
