Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
All earphones not working even though chargers do
Hello there, I have an iPhone 7, with 128 GB. I haven't been paying it much attention recently, but I think it might be failing me somehow. It has about 35 GB of memory left, but its performance has been so bad the past few days. For instance, the camera often freezes, sometimes does not take a picture although everything looks like and feels like I've snapped one, the camera lags and freezes up when I try to switch camera, the Apple Maps suddenly stopped working - everything resulted in a 'No suggestions found' and walking navigation did not work as well (but it fixed itself a few hours later when all I did was surf some sites and watched 2 predownloaded episodes of Netflix). I thought it might be a memory issue as I have been travelling and I did not have time to backup all of my photos and videos (pretty sure it's the only thing taking up 80% of the memory) and I tried to use the 'iPhone Storage' function but it often freezes up or become unresponsive or when the screen goes black it just goes back to the home screen when I unlock it again.
The biggest problem that I wish to talk about is (I mentioned the above just in case someone knows if it's linked altogether or if I probably just need to get a new one or do a hard reset or something...)
So currently, my earphones/earbuds don't work. They are the ones issued along with the iPhone itself. I have 1 that came with this iPhone 7, which only has the lightning jack as well as my older one from my iPhone 5S or 6 (can't remember) as well as the audio jack to lightning adapter that came with this iPhone 7. Both of them do not work, and instead, the audio is played from the iPhone speakers when I plug any of the earbuds in. The earbuds do work as I have just tried them on a computer. The lightning dock does work as well as I managed to charge it through the wall last night, as well as from a portable charger while I am on the go.
Currently, I have only tried restarting the iPhones and hard restarting it. Also, trying to clear the lightning dock of debris (if any), as well as tracing both my audio cables to look for any breakage of sorts, but the older cable does work as I plugged it into another audio source. Any help would be really appreciated!
crwdns2889612:0crwdne2889612:0 20
crwdns2944067:04crwdne2944067:0
The issue i appear to have is that on my iPhone 7 i have a home button that functions but doesn’t vibrate, this goes for anything else that is supposed to vibrate. I’m losing battery at a rapid rate to the point where i get 4 hours screen time tops out of my phone and my lightning port works for charging but not for earphones, i have restarted the device and soon after they register, i can play music for about 15 seconds and then my phone no longer recognises the headphones and reverts to using the built in speakers
when my sisster pluged in her earbuds she could not hear anything why
I hаd a similar іѕѕuе with my earphones.
Fіnаllу I mаnаgеd to resolve thе problem.
Follow thіѕ guide hеrе: https://bit.ly/3qrsi8w
Hope thіѕ will be helpful
Don't click on the link above, virus total flagged it as malicious.
crwdns2933315:017crwdne2933315:0
You have to connect lightning to iphone via bluetooth. Open Setting - Bluetooth, then you’ll see “Lightning”. Pair it, then your earpod will get connected.
crwdns2889612:0crwdne2889612:0 8
crwdns2944067:011crwdne2944067:0:
You cannot connect a lightning cable to Bluetooth. How does one connect a wire to a wireless connection? The two are not interchangeable. Please revise your answer.
thanks for the information
Thanks, it finally works!
Thank you!! I would never have thought to look in the Bluetooth settings to connect to the lightning port - but it works!
Thank you it works
crwdns2934275:06crwdne2934275:0
The usual test for seeing if u have the audio ic issue is the following 2 symptoms
  • Long boot time, takes ages for the phone to start up
  • In the voice memos app on the phone u cant record a voice memo will say something along the lines of no playback devices available etc
If you have those 2 symptoms its likely u have the audio ic issue caused by the phone flexing, it is a repairable fault however requires microsoldering
If you dont have those 2 symptoms then try cleaning the port make sure the headphones or the adapter plugs cleanly inside the port should be a small gap about 1mm o so all around any more and u might have something stuck in the port :)
crwdns2889612:0crwdne2889612:0 7
Pls help me. Everything works normally, including the microphone, except for the headphone adapter that I connected. The headphone adapter works because I tested it on other devices. The device also charges and transfers pictures normally and I have also cleaned out debris.
Headphone adapters are very very flimsy in my opinion so I wouldn't recommend trying anything else till u try a genuine replacement adapter... cheap copy adapters stop working after software updates etc or just dont work in general
the headphone adapters work on all other devices however, so is there anything that I can do to make it work.
same situation. all headphones work on other devices.The port works perfectly with charger jack.I believe its a setting issue rather than hardware. If the headphones are only triggered on only when the phone detects they are inserted...that means three an error in the internal programming that routes this action. There are no audio output settings for the iPhone unfortunately . Ive taken all the same steps to no avail and apple tech seems to have no answer.
I backed my iPhone 7 up through iTunes and then restored it after completely resetting it. Worked a treat
STEP 1 - Plug in the headphone adaptor. Wait 1-2 seconds, this is to allow your iPhone to recognise the new device.
STEP 2 - Turn on Bluetooth from Setting (Yes, I know it is not a Bluetooth device. Take that up with Apple).
STEP 3 - Connect the device. (it will be shown as GA or Lightning )
STEP 4 - Plug in your Headphone and Enjoy
ok I'm going to try this once I finish my reset...which according to other comments was probably for nothing;(
This worked for me thanks!!
Thanks man!! it worked for me too?
Thank you. Worked!!
This one really worked, Thank you so much. Sending virtual hugs as gift ??
Try to Restore it with iTunes with the latest software. If the problem is the same so you have to reball the Audio IC and make a jumper C12 with R1103.
I have no idea how to do any of those things :/
Ohh, to restore it go on youtube and type iphone 7
Sorry, go to youtube type iphone 7 restore with itunes tutorial and you have a lot of videos that will show you how to do it step by step (it's not a hard thing), as for the other solution it is better if you send it to a good microsoldering technican to do the job (audi ic and the jumper), i hope you can fix it only by restoring it
Jessa from iPad rehab has an amazing tutorial on how to do this.
Hey I bought my iPhone 8plus in July 2019 but my earphones are not working yet have never even tried using them
My back camera is not working as-well,when I try to capture a picture it shows darkness only
I tried watching most of the videos to solve my problem but nothing is helping me out.Any advice about this please because I need to listen music in earphones and I travel a lot I can’t take any picture.Please help me and thanks much
Sounds like the typical "audio ic" component failing on your device. It either starts with your ear speaker failing or your charging port not outputting audio. This is a repair that require someone that knows how to solder.
If you want to ship your phone out i can get you in contact with someone that has done a phenomenal job with all the work i've sent him thus far. (Touch ic, backlight filters, audio ic, etc)
So I’ve got the same problem but voice recording through the app works fine. So is it something else causing the problem?
Phone charges fine, just doesn’t recognise any headphones are connected.
This is the same issue as mine. All works fine apart from headphone detection when plugged in.
I bought another 7 Plus for the time being but will probably send my old one off for audio IC repair.
When I do if it fixes it I will update here.
Headphones not working the first point to check would be are u using an adapter and tested headphones is the adapter original... try another adapter and headphones copy adapters like the first copy lightning cables do just stop working after a while. Failing that try a new charging port, it doesn't matter if charging still works.
I have also similar issue in iphone 7. After the new update i cannot hear any phone calls even there ringtone. Youtube is working fine. You can play music from library. Headset is not working. External bluetooth headset working fine during calls.
everything fine before the update. Phone has not dropped at all. There is no any physical damage from outside. Apple store said whole unit need to replace.
i have already restore to factory setting but still not work.
Please comment below is there any-cheap way to fix
This is a well documented problem. Your audio IC has failed. Specifically, the solder joint has broken away from the trace on the logic board. Updates will likely surface an already existing issue.
please help. I also have same problem with my iphone 7. phone charging normally,no derbies in port, but earphones not working when i increse the volume with button it shows volume instead of ringer help me if my charging flex is short or audio ic is faulty?
I am facing the same issue with my Xs max, charging is working fine, but headphones are not detecting,,restored 2 times, my airpods are working fine with the mobile..
I wondered if that wouldd be the case,interesting
@Chris Storer
My 7 failed after iOS 12.3 update. Was working fine prior but after update I had slow boot and no voice memo recording. The usual audio IC failure indications. Had it repaired and sorted.
also have a 7 Plus and like OP have no headphone detection but earpods and jack adapter work ok in other iPhones.
Did a very quick dock port swop, still same but wonder if I did this too quick now as was rushed. No audio IC symptoms showing up and have not read anything about the link between audio iC and headphone detection though not ruling it out.
anybody else got any suggestions?
If the audio IC is bad then it absolutely will not detect headphones. The audio IC is responsible for sending pulse width modulation (PWM) patterns to the CPU and other components and without that frequency, nothing works. Headphones are just the beginning.
@ Chris Storer
thanks for that answer. It appears to be another audio IC job then for me. 3rd in about 3 weeks.
I will investigate this one further snd report bsck my findings.
Cheers
I never heard back from you on this topic. Did you ever figure out what was wrong with your iPhone? Just curious.
Hi, just wanted to pist an update to my previous post.
Ok, I sold the iphone with the headphone detection problem in the end.
I had another 7 with audioIC and headphone detection issue. Just come back from repairer which has fixed AudioIC problem but headphone still has issue. :(
Repairer stated it might be a circuit bias problem.
Thats all I know right now but if I can get it fixed I wlll update again.
Please help me i have problem similar to it not exactly same. First of all i dropped my ip8+ while it is connected to the usb lightning cable then it started to not charge. But lightning earphones work properly. I tried other usb lightning cable and it doesnt charge. Is there any chance that charger can be damaged while earphones working fine. Im confused because charging and headphone jacks are same isnt it?. Plug earphones it works(music sounds perfectly without crackling sound)and plug usb lightning cable to charge it doesnt charge.
Hey there, I was just looking up this issue as well because I have just tried using my dongle and headphones and it wasn’t working either, just playing out the I phone speakers.
I didn’t want to restore the phone so I just unplugged the dongle and flipped it around and re plugged it in and then it worked, I don’t know if that helps at all or if that will be the case with the new I phone 7 headphones but good luck!
Unfortunately the audio IC symptoms vary from device to device.
I called apple yesterday and the Genius I talked to says he has never heard of an Audio IC issue.
My voice memo won’t record and my Siri can’t hear my voice…Needless to say i can’t make a call either.
Same, I can’t make a call, nobody can hear me when someone calls, my earphones sometime work then nothing, I tried to clean my charging
Port that didn’t work either. My voice memo & Siri can’t hear me
It's audio ic issue
hi, i think i’m having a similar problem. my iphone 7 can’t play audio in the lightning earphones, it just played out through the speakers. charging works tho. but i have one more problem, the microphone isn’t working. i can’t record voice memos, or make a call, and no audio when recording a video. but my iphone boots normal, not stuck at apple logo. hope this problem could be solved
I’ve had the same issue, what i did was by doing reset network. It helps me to be able to make a call. However the earphone issue is still there
I have the same issue with my phone, though only solution I have found is to use Bluetooth earphones.
If your earphone don't work then you must change the audio ic. It will solve the problem.
Hello,
i found a video on YouTube which shows this problem and how to repair it:
https://youtu.be/VFxS3ORQwE4
Even if pluged in,the headphones need to be paired by bluetooth!The charging will work regardless!
My headphones won’t show up under Bluetooth what do I do?
Zi Jing crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 74
crwdns2936753:030crwdne2936753:0 227
crwdns2942667:0crwdne2942667:0 179,129
