7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
How to remove screen once been glued down after repair
hello we have had a mini ipad fixed last year and been sitting in cupboard, they had to glue the screen down as it kept popping up in a corner.
but we now have a problem with a section of the screen not working at all, so need to get a new part but how do i remove the screen now that it has been glued down?
annoyed with local repairers what to buy the equipment and have a go myself have replaced batteries and screens on iphone already.
thanks for the help.
Well I use a hot plate to heat up the iPad to 80°C then I use a razor blade to start lifting up the glass a bit from the side then slide a thin plastic flexible card with either ethanol or 99% isopropyl alcohol on it and slide across the edge only (never go too deep in, you can scratch the LCD or damage the antennas at the bottom.)
There is also a guide on how to remove the front panel glass:
iPad Mini Wi-Fi Front Panel Assembly Replacement
Use the images of the screen as reference to how deep you can put your prying tools (plastic card etc) in.
hi thankyou for your help, noticed people have said hot plate, now is that just hot plate like in kitchen? or is there a piece of equipment i need to buy?
It's a piece of equipment that can be bought. Usually in a form of a heat mat or looks like this
https://img.staticbg.com/thumb/view/oaup...
ben crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 65
