Ice maker not working
I have a whirpool fridge that has an ice machine in the bottom drawer freezer. We bought the fridge about 2 years ago and the water line was never connected until recently. I just hooked up the water line and no ice. The wire arm was disconnected from the front of the machine somehow at first ( it probably got caught on something and got pulled out but I put that back in ). What all could be the problem?
Cause 1
Freezer Temperature is Above 10 Degrees F (-12C)
If the freezer temperature is above 10 degrees Fahrenheit (-12C), the ice maker will not produce ice cubes efficiently. The freezer temperature should be set between 0 and 5 degrees Fahrenheit (-18 to -15C) for the ice maker to work properly. If the freezer temperature is too high, ensure that the condenser coils are clear of debris and the condenser fan is working properly. In addition, check to see if frost has accumulated on the evaporator coils. If the evaporator coils are frosted over, part of the defrost system has likely failed.
Cause 2
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
Cause 3
Ice Maker Assembly
One component of the ice maker assembly might be defective. Since many of the ice maker components are not sold separately, you may need to purchase and replace the entire ice maker assembly. Before replacing the ice maker assembly, check the water inlet valve, water line, and fan. If none of these parts are at fault, and the freezer temperature is at least 15 degrees Fahrenheit, replace the ice maker assembly.
First, make sure the water line is properly connected and there’s no kink or blockage. Check if the water valve is turned on and the water is actually flowing to the ice maker. Since the wire arm was disconnected, it could also be that the arm is not sensing the correct ice level, or the ice maker could be in a "paused" state. You might want to manually cycle the ice maker to see if it starts producing ice. If it still doesn’t work, the issue could be with the ice maker’s motor, thermostat, or water valve.
Shelby Rupright crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 406
