Duel Samsung 860 EVO Running RAID Zero in newer iMacs possible?
Hello, and good day!
I have my iMac 2011 27” Running 2 Samsung 250 GB 860 EVO SSD’s
Running RAID 0 and it’s kick ass!!
I love it so much that I’d like to do something similar with the updated model.
Which 27” iMac model will work here?
  • 2012-2015 i7 3.4 MHz
  • Be the best bang for the buck?
  • Retina is a must or 5K
  • Memory doesn’t matter as
  • Update it myself only if Possible
  • Video card two gigs or better
  • Drive doesn’t matter as I will
Upgrade on my end..
And lastly how much you think I can get on my set up already as I’m going to use the proceeds to fund my new project?
  • 2011 iMac Intel i5 3.1 MHz
  • AMD 1 GB Graphics card
  • 24 GB of memory
  • 2 Samsung 250 GB 860 EVO SSD’s
  • Running in Raid 0 500 GB total
  • Running Sierra
Is still not officially supported that’s a whole Other matter Lol..
ATT: Dan Please feel free to jump in. As you were the reason I started this Project.
Thanks in advance.
John,
Sadly, you really can’t run RAID internally with the 2012 and newer iMac’s. The reason is they don’t have dual I/O ports which run at the same data rate which is a requirement for RAID to work well.
But you could use an external RAID drive subsystem via Thunderbolt2 or 3 (depending on the model)
The best option for I/O speed internally is going with the new iMac Pro there you have a dual channel all setup and is doing RAID 0.
Basically, you have the best iMac for internal RAID now! While it’s only SATA III (6.0 Gb/s) it still smokes! Save your pennies for the iMac Pro ;-}
Thank you so much for your honesty
Sorry its not what you wanted to hear.
iMac mid 2011, try to do fusion drive Samsung 860 EVO - error, don’t work, try to do additional driver to CD-ROM cable, sometime iMac see SSD sometimes fully missing, so i spent 2-3 days, than i thought SSD broken, check it for all test on another PC computer all work well, try again iMac - no result don’t work and all. So i have do conclusion iMac mid 2011 27 inch don’t work with new samsung 860 EVO 250GB , by the way still work my fusion drive at my old 250GB Samsung EVO 840.
John R crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 717
