The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Red light flashing 3 times. Won’t turn on.
Hello
If I press the post button on my OontZ Angle 3 I get a red light that flashes repetively in groups of three.
If I hold the power button down the speaker works (but the red light keeps flashing). As soon as I let go of the button the speaker dies.
I have tried charging with multiple cables.
I have tried to find the reset button through the auxiliary jack, but I don’t feel anything in there that feels like a button.
Any ideas?
Update (05/25/2018)
Has anyone successfully found the reset button?
I do not have mine with me at the moment (I am currently at work), but if there are no responses on this post when I get home I will check on my OontZ.
Bump. Anyone have any ideas?
That did not work with the paper clip
@jytug71kv4zrzki, No, the paper clip isn't going to work because there's no reset switch hidden inside the input jack. Oontz itself offers instructions on how to reset the speaker.
First:
Resetting Your OontZ Angle 3
Note: The reset function only applies to speakers purchased after Sept 1, 2016
Step 1: Remove the Micro USB charging cable and 3.5mm Audio cable, if connected
Step 2: Press and hold down the Power button and + button together for 1 second, then release.
Step 3: The speaker has now been reset and can turn it on.
Note that the Angle 3 ULTRA has a different procedure; for that model you hold down the power button for 8 seconds.
I have the same problem, tried the reset steps (both of them) Speaker is still flashing red light in a 3x time pattern.
It will not charge. 😪
Same. I finally gave up and just bought a new one after all that frustration! Ugh! Disappointing bc I love this speaker!!!
The speaker will continue charging if I hold power down red light flashing. I release hold it stops charging.
Ben Ereddia crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 4,372
