The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
crwdns2934591:01185crwdne2934591:0 crwdns2934593:0crwdne2934593:0
New Aura Pro SSD not recognized
Here is the situation:
- The original SSD in my MacBookPro died (verified by diagnostics run by the genius bar at the apple store).
- I purchased and installed a "240GB OWC Aura Pro X SSD (Blade Only)" from MacSales.
- The new SSD is not recognized using recovery.
- I only have access to windows machines to try and revive the MacBookPro.
The MacSales site states:
"macOS 10.13 and later versions include an EFI (firmware) update that
adds support for the Aura Pro X to the host computer. If you do not first
update the host firmware by installing macOS 10.13 or later onto the
existing SSD, the Aura Pro X will not function properly once installed."
I'm pretty sure that the original drive had High Sierra on it because I tried to reinstall OSX by booting with Command-R and it was trying to install High Sierra (before visiting the Apple store).
Is there a way to make a bootable USB with High Sierra on it using windows? Or another way to get out of this mess using the tools I have (a MacBookPro with an un-formatted SSD)?
Help.
Ah perfect this solved my issue. I replaced my logic board and the firmware on it did not support my Aura Pro X SSD I already had installed. Pulled out my stock SSD and installed 10.14 Mojave on it and immediately swapped in my Aura SSD and it all works perfect. Thanks very much!
Weird, this doesn't make sense to me. I'm using an early 2015 Macbook Pro 13" A1502 running Catalina which was upgraded from Mojave a few weeks ago. Now I installed a new Aura SSD X2 480GB OWCS3DAPT4MB05. When I used a bootable Mojave USB that it's known to be working. I used it and a co-worker used it to restored two other MacBooks. I can see the SSD and format it, but when I try to install Mojave said the install USB is corrupted. I then try Command + R using the internet recovery try to restore to El Capitan, it wouldn't see my SSD.
The failure to install Mojave with an 'installer damaged' issue is quite possibly because you are using an older copy of the installer, with an expired certificate:
https://9to5mac.com/2019/10/24/macos-app...
links on the page to fresh copies
Well you are in a tight spot...
You do need to find someone with a Mac that allows you to create a USB thumb drive OS installer.
It comes down to which came first the chicken or the egg ;-}
I'm sure you can find someone to help you even the Apple Store should be willing to help setup the drive (ask nicely & smile!)
Here's the steps you'll need to take: How to create a bootable macOS Sierra installer drive Or How to create a bootable macOS High Sierra installer drive
Save the thumb drive for the next time.
I was able to use the instructions from this video to make a USB installer in windows.
https://www.youtube.com/watch?v=dTUEWA4i...
It worked great. As soon as I booted with the installer, High Sierra recognized the new drive immediately.
Wow! Thats cool.
Its been awhile I've looked for such a method. Happy you got things working.
Your help was very useful. It helped to verify I was on the right track.
Another solution is to do a clean install of macOS 10.13 or later version from recovery mode onto the Aura Pro. dont need to configure the os.
After that update to whatever os the latest time machine entry is. Then restart the mac and hold cmd + r to start in recovery mode (should be from disk) then select recover from time machine and your computer should regonize the Auro Pro since it now has a mac os installed and can restore from time machine from it.
I upgraded my MacBook Air (early 2015) to the latest macOS Monterey, v 12.0.1. Installed the Aura Pro X2, but the mac did not recognize it. Reinstalled the old SSD, no problem. (So the connectors etc on the mac must be fine. ) Installed the Aura Pro X2 in the external enclosure that came with the bundle. The enclosure powers up, but, the mac still does not see it when connected via USB port. I believe the Aura Pro X2 that was shipped to me is defective but, not sure how to get help beyond this. Wasted over $500 on this effort.
Sorry guy the OWC case can't support the OWC Aura drive. Its firmware is strictly designed to support the custom Apple Samsung SSD's only.
As far as Monterey its still buggy! And even Apple has issues with it! Apple fixes bug that caused macOS Monterey update to brick some Apple T2 Macs
At this point you'll need to visit an Apple Store to see if they can help you.
Thank you, Dan. Do you think I should go back to Sierra?
@Michael Hayashi - Yes!
Sierra is not a good choice. High Sierra may have been an acceptable answer at the time your question was posted. It's far too old to properly support even safe, functional web browsing using Safari. Every operating system is 'buggy'. Catalina (preferred), or perhaps Mojave, are the minimum macOS versions you should consider at this time. If your Mac supports Big Sur, they you should feel confident that the macOS that has been out for over a year is a reliable option. Modern, bug fixed, secure. Unless there is some old application that just won't run on the latest or previous macOS version, try to keep current.
@rareit - OS and web browsing are still very different! Sierra is still very safe. As far as Safari you can upgrade it independently, or just get another newer browser.
And lastly, run a good antivirus and malware and keep it updated.
I do recommend going to Mojave vs High Sierra if you have a SATA drive'd system. If you have PCIe/NVMe drive'd system then it gets tricky! As Big Sur & Monterey both have issues. I'm hoping the next macOS fixes these issues.
David Headrick crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 12,242
