Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
JBL is not turning on
When I try to turn it on with the buttons, there is no lights and it simply doesn't turn on.
When I charge it, I can see that its fully charged with the green bars.
There's no damage to it that I can see
crwdns2889612:0crwdne2889612:0 23
crwdns2944067:023crwdne2944067:0
Need help please can anyone tell me:- I have ordered JBL Xtreme from myntra and when I receive that after unboxing I was unable to start and after I tried to plug charger it still not showing any lights or sign it is on can anyone tell me what the issue I have got or how can I fix that please
If any secret button to turn on
Help please i have the same problem
i have the same mistake with the few times.I read something on the internet.you have to: 1.do the power in the JBL Box 2.Hold the voulme down(-) and the connect + button for 10 seconds. 3.the JBL say seven seven. 4.take the power From the electrical Wall 5.Now do the Power in the JBL Box again. 6.Now hold the play and volume up (+) 7.the box goes off an if you starting the box it have to be normal.
Thank you Spongebozz; it worked!!!!
It really worked.
crwdns2934275:018crwdne2934275:0
I just fixed this issue on my JBL Exteme 2:
Issue: JBL shows connected to device but not playing audio. I tried factory reset but ended up putting speaker into weird stationary mode, which locks you out of basically all functions of the unit.
Device was connected but not playing audio. I attempted hard reset but held down the wrong keys. I held down (JBL Connect +) and the (Volume +) buttons, after 10 seconds the device powered off and I was unable to power back on by pressing the power button. While in this mode, I could only get the power light to turn on when plugging the speaker into the power outlet, then the power light illuminates the color white instead of the Blue I am used to seeing. In addition to powering on only when plugged in, I can only get audio to play via 3.5mm in this mode as well.
To get out of this mode, you must plug the unit into power. Once the unit powers on and you see the power button lit up White, then hold the (JBL Connect +) and (Volume +) buttons until the unit powers off. Then unplug, press power button (do not hold, just press), and the unit will power on with the power button illuminated Blue. Now, reconnect your device to bluetooth and whallah!
In my situation, after connecting my device to the speaker via bluetooth I still had no audio coming from speaker although the phone said I was connected bluetooth. I hooked up my windows laptop to the speaker via BT, played a youtube video for a few seconds and the speaker worked perfectly. Reconnected my phone and now it’s working perfectly. I think a recent Apple update caused something weird to happen when connecting to bluetooth.
If you run into the issue of establishing connection via BT but no sounds, try connecting a totally different brand device to the speaker to trigger a type of internal reset.
If you attempt to factory reset, and end up hitting the wrong buttons and put your speaker into this weird mode that is not mentioned in any catalogs or anywhere online, just make sure to hold down whatever buttons got you into that mode everything should go back to normal. For me, I messed up by holding the JBL Connect + button and Volume up buttons, I got myself out of the issue by holding the same buttons. Took me a few hours to figure this out.. Hope this helps.
crwdns2889612:0crwdne2889612:0 21
crwdns2944067:016crwdne2944067:0:
Very helpful. Although, getting some where with the speaker, power button is now lit blue but blinking. Thoughts?
Never mind, it took a bit, but finally reset and paired. Thanks for help.
This worked! I was so worried. Thank you so much! Just wondering, is there warranty that comes with the speaker? If there is, how does that work?
yo guyza my $@$* has been &&^&@@ up for dummy long and I tried that $@$* and it worked asap so lmk when and ill blow u;)
i cant turn it off tho
crwdns2934275:011crwdne2934275:0
I had a problem with my JBL boombox not turning on or charging. Spoke with Harman international industries and was advised to plug the charger into the boombox but not the mains power supply and hold the power button for 60 seconds minimum for a factory reset. This solved my problem and it powered straight back up. Hope it helps you.
Boombox 2 won’t turn on after firmware upgrade. I tried a firmware upgrade but the power button and Bluetooth stayed white after completion of the update. I tried to turn off but it didn’t. I don’t remember what I pressed to turn it off. But I remember holding on to two buttons for some seconds and it went off. Now speaker won’t turn on or won’t charge. Please help.
Spoke to jbl support but no help. W
@djsuicide Thank you, that solve mine too. You just saved me some bucks!
Please my JBL xtreme3 doesn’t come up after a hard reset when it wasn’t powering off. The power light just blinks white and it goes off. If I connect it to power with the cord the battery indicator charges and shows full and the power light stays permanently on . The power on sound also comes up once connected to power . The Bluetooth connect light doesn’t come up . The moment I remove the power cord the power light goes off and the off sound also sounds . Speaker still doesn’t come on , power light just blinks and goes off
Hi Idris,
I just fixed this problem on my Xtreme 2. Turns out we had an issue with the charger. This caused the battery to malfunction just like you describe it.
I replaced both battery and charger and lo and behold: she works like a charm again.
Even if your charger is fine, it is likely that your battery is toast. Replacing is child's play, took me 10 minutes + watching a tutorial
Kasper
My JBL xtream 2 doesn't show any lights while plugged in for changing and shuts down in 5 seconds or less after turning it on. Is this the battery or the charger?
Its the battery
Hate to say it, but mine does the same thing, replaced battery, still does the same thing.
It not the battery it have pannel issue
Try:
  1. Plugging into charger to get lights to turn on. (Should be white power light and battery lights)
  2. Hold down JBL+ and Volume + Button together for 10 seconds, unit should power off.
  3. Unplug power cord and press the power button, light should light up blue and issue resolved.
This fixed mine. Seemed to have helped a few others in the site as well.
best of luck!
In my situation the usb port "wobbled" and eventually I was unable to charge the speaker. This was a disappointment as it had only been charged a few times. I had trouble with warranty as I purchased it while overseas. A further disappointment! JBL had always been my choice in the professional gear. I subsequently "binned" the unit and will replace it with a unit with a more serviceable charge port.
@argydubbaya just order a new charging module. It comes complete. Just a few screws and u r good to go.
My Extreme2 is brand new. Out of box it will not power up. I see the battery charge indicator lights. Tried with and without power source, with a full charge. Tried all of the steps I could find on line. No luck. Just short of returning it, not sure what else to try.
My JBL extreme 2. When I power on it just switch off automatically. I have charge the whole night and the battery light still blinking at one bar only. What could be wrong?
well, i changed the battery pack, 2yo. thinking probable cause
my unit powers up, plays for 5 seconds then i get a red blinking light an it powers off.
any ideas as to what next would be appreciated. thx
Thanks alot brother u was really stuck in the same situation u got into, but thank God found ur sulotion here, God bless you
Arnold Chen crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 21
crwdns2936753:07crwdne2936753:0 130
crwdns2936753:030crwdne2936753:0 488
crwdns2942667:0crwdne2942667:0 101,286
