Repair guides and troubleshooting for the 40in LCD TV with model number LA40R81BD or LA40R81BDX. This television was released in early 2007.
The screen looks like X-ray vision
I thank I have the same problem the screen looks like X-ray vision would that be the same problem. Would that be the T con bord I have a another Samsung TV that has line's and Bar's running through it so I'm asking do you thank I can take the T con bord out and fix the X-ray vision any good information on how I can use the parts out of one to fix the other I would be very grateful if you think you can help on this project I really don't have the funds to buy another one hope to hear back from you soon thanks
my samsung flex3 pictures look like x-rays, how do i fix it.
@jimmydean sounds like your TV screen has developed solarization issues. Post some images of what your screen shows with your question. Use this guide Adding images to an existing question for that so we can see what you see. This could be a T-con error, Main Board or panel failure. If your on-screen menu is normal but your video screen is distorted, it is most likely a bad Main board. If both the menu and the screen are solarized in appearance it is either the t-con board or the panel.
sometimes the t-con board is interchangeable but this will depend on what model your TV's are.
James crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,412
