Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Can I use iPhone 8 battery in iPhone 6s?
I'm aware the connection pins are bit different but size-wise they're identical, and plus you will get a bit more power, so why not?
Has anyone tried it? I'm also sick of waiting for iFixit's replacement batteries to be in stock in Europe. I've been waiting over a month and I can just buy a 7/8 one.
The voltage is the same, but the size might be be a problem, the iPhone's battery is designed to have some space for expansion, Installing a battery that only just fits might be dangerous. As for the connector: you can cut off the original connector of the old 6S battery at the nickel strips and try to spot weld it to the 8's battery nickel strips. Wouldn't recommend it though. There are some reliable iPhone battery suppliers in Europe apart from iFixit.
fixshop.eu might be of help
IFIXIT has it in stock! iPhone 6s Battery
crwdns2886500:0Replace a 1715 mAh battery compatible with an iPhone 6s. This replacement does not require soldering and is compatible with iPhone 6s models (not iPhone 6, 6 Plus, or 6s Plus).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 6s Battery
$29.99
I mentioned I was referring to the Europe store.
Sorry ;-{
The demand is high with Apple's replacement program stripping the suppliers.
Your only hope is if you have a friend here in the states who is on his way home he can carry it in this land luggage.
Battery's are rated differeny for those phones different voltage and capacity and connector if u even can force a connection like on the 6 and 6s u risk frying the board... DO NOT DO THIS
Also you could damage the connector on the board easily.
i wouldnt think so, why do you not just order a higher capacity 6s battery online
Aren't they dangerous? I tried searching if anyone has done it but no one has
i usually just use the original capacity, so it would be your choice
U could burn out the board and battery as well do not recommend
I have old 6s with a new battery fitted still at 100% and a iPhone 8 3rd generation with battery at 83 % just wondering if the battery from 6 would work in the 8
becruily crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 15,336
