Repair guides and troubleshooting for Presario CQ58 series. These are budget laptops made by Compaq, which was owned by HP from 2002 to 2013.
Why my airplane mode button wont turn off
my airplane mode button won't turn off it is orange all the time and i can't access internet. i have tried different ways to connect to wifi using usb tethering, usb wireless port but still i am not able to access internet as the button is stll orange what can i do to turn it off?
Go to HPs website and see if there is an updated driver.
There are a few laptops with an airplane mode bug that needs a patch directly from the manufacturer.
there are two different ways that you can turn off your PC's airplane mode
1: you can disable airplane mode in the notification panel.
2: run the troubleshooter.
3: check the services in the computer manager if it's not running then right your mouse on it then click start.
Also, check for a keyboard shortcut that enables and disables airplane mode. (Like Fn + F11). Also, you can disable airplane mode in the notifications panel on the right of the screen.
I have had this issue before, but it was on a del laptop. I ran the troubleshooter, and it fixed the issue. Try going to start and searching troubleshooter, It should bring up a page to run different troubleshooting tests.
mine isnt working even after troubleshooting. it just states i need to connect ethernet courd in order for my device to work! and i dont own an ethernet, i will not be buying one either.
sanelisile crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,708
