Repair guides and troubleshooting for Presario CQ58 series. These are budget laptops made by Compaq, which was owned by HP from 2002 to 2013.
crwdns2934591:022crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why my airplane mode button wont turn off
my airplane mode button won't turn off it is orange all the time and i can't access internet. i have tried different ways to connect to wifi using usb tethering, usb wireless port but still i am not able to access internet as the button is stll orange what can i do to turn it off?
Go to HPs website and see if there is an updated driver.
There are a few laptops with an airplane mode bug that needs a patch directly from the manufacturer.
crwdns2942205:01crwdne2942205:0:
there are two different ways that you can turn off your PC's airplane mode
1: you can disable airplane mode in the notification panel.
2: run the troubleshooter.
3: check the services in the computer manager if it's not running then right your mouse on it then click start.
Also, check for a keyboard shortcut that enables and disables airplane mode. (Like Fn + F11). Also, you can disable airplane mode in the notifications panel on the right of the screen.
I have had this issue before, but it was on a del laptop. I ran the troubleshooter, and it fixed the issue. Try going to start and searching troubleshooter, It should bring up a page to run different troubleshooting tests.
mine isnt working even after troubleshooting. it just states i need to connect ethernet courd in order for my device to work! and i dont own an ethernet, i will not be buying one either.
sanelisile crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,599
