Why is my tablet on Safe Mode?
Hi, I have a problem with my tablet. Whenever I turn it on, it's in safe mode. It seems that the DOWN VOLUME key is always pressed. Any way to fix it?
Volume down key needs to be fixed to keep the tablet out of Safe mode as when that is held down while the tablet is turning on, the tablet will boot into safe mode.
Either the volume down button is jammed or needs to be replaced usually. You may find mobile phone repair shops in your area that can fix this problem for you. Shouldn't cost much.
Thank you. I was very frustrated after continually pressing off and on again with no results. I have an older case for my tablet and it presses on the volume button if the tablet slides down in the case. Thank you.
crwdns2942667:0crwdne2942667:0 2,632
