Touchpad Pointer prematurely executes when it "hoovers" over something
When using the touchpad, and moving the pointer around, if it moves across an executable item, even "hovering" over it for a split second, it executes that command before you "click" on the touchpad left button as you would expect to do.
This is horrible, and I can't imagine that this is the way it's intended to work. Is this something that can be fixed with a setting change, driver change, or otherwise?
What Operating system are you using?
Looks like I've found a "fix"; in "settings", touchpad, turn off the "finger tapping" option -- this seems to have worked ok.
Byrne Whitehead crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 131
