The Audi A4 is a compact executive car produced by the German car manufacturer Audi AG. The 2002-2005 A4 was built on the Volkswagen B6 platform.
Oil inside the coil
What those it mean when there’s oil inside the coil
Usually most of the leaks on the outside of the block or inside the cylinder combustion chambers are the result of a faulty valve cover gasket. When this happens, all you need to do is just replace the valve cover gasket. Installation of a new component is rather a straight forward process. To get the job done, follow the process:
  • Remove the valve cover from the head of the engine
  • Remove the old gasket
  • Keep the area clean with a rag
  • Spray some silicone spray where the gasket will be placed
  • Place on new gasket
  • Put the valve cover back, and torque valve cover bolts back to spec.
EE408 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 170
