Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
crwdns2934591:0873crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Backside Metal or Plastic?
Is the iPhone 8's backside under the glass of metal or plastic?
Thank you.
The outer housing (perimeter) is aluminum while the inner back plate is stainless steel. Check out this teardown guide.
crwdns2942205:01crwdne2942205:0:
@danj is correct, I have amended my answer...
It looks like steel to me.
The spot welds along the edge of the studs are bluish which is what steel would look like. In addition the thinness of the metal given the needed strength would imply steel as well. True the outer side edge is anodized aluminum!
It is metal. See this phone
Mandy you are correct. It is made from stainless steel.
Hi, the back is metal with a frame (Al) and covered with Glass.
It is metal covered with glass, however i don,t recommend this phone if you want a strong one a video from the channel jerryrigeverything the back glass broke dramatically after only the second from lap fall . If you a good powerful phone i would recommend the xperia xz premium.
crwdns2889612:0crwdne2889612:0 -1
Hans crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 571
