Released by Nikon in January 2014, the Coolpix L830 is a compact digital camera designed to provide powerful zoom with simple operation.
My power will not turn on even with new batteries
my power will not turn on the camera even with new batteries
@roovb2000 always check the battery door first. If it does not close properly your camera does not get the power. You also did not tell us if this camera worked before you changed the batteries or if there was any prior damage.
Yes door shut worked fine before said battery exhausted replaced several batteries
Just to make sure, you did insert the batteries the right way (not trying to insult you but it does happen) Also check the answer by @flyingdutchman on here Why won't my Nikon Coolpix L830 camera turn on?
I'd hate for having to tell you that you have to tear your camera down and check the DC-DC board etc. Schematics are almost non-existent and we do not want to send you down a proverbial rabbit hole
'''Camera does not power on
'''When the on/off button is pressed the camera does not turn on
'''Low battery
'''If the camera does not turn on, check to see if the batteries are low. If they are low then see guide Nikon Coolpix L32 Batteries Replacement. If the batteries are not low, read on.
'''Batteries are put in backwards
'''If the batteries happen to be put in backwards then the device will not power on.
steven dallman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,948
