The Dell Inspiron 14-7437 is pre-installed with Windows 8, has 4th generation Intel Core processors and a 14-inch display.
Why does my laptop say no bootable device?
I asked my brother and he said it needed windows 7 but I don't know how to do that. He gave me a flash drive with windows on it but it doesn't do anything . Can you guys help me !
@gmej1your computere can either not find / read the hard drive (HDD failure)or the files on the hard drive are corrupted (OS failure)
You need to try and access the BIOS on the computer and see if the BIOS can see your hard drive. If it does not it is most likely a failed hard drive. To repair that you would have to replace the drive. The "owners manual" downloadable from here will tell you how to work on your hardware.
To access your computers BIOS try this:
Turn on your computer.
Press "F2" during boot when the "DELL" logo appears.
Press "Fn"+"F1" after the computer has powered on if "F2" does not work. The BIOS menu will display with a list of options.
This videoshould be pretty identical to your BIOS as well. It is within the BIOS settings that you can set boot mode to USB drive and try to boot from your flashdrive. It has to be bootable. You could also use a Live CD version of Puppy Linux and use that to boot. With that, try to access your hard drive.
go to bios
1-secure boot make it disable
2- go to boot or advanced boot there is something uefi make it legacy or csm
3- save
4- if dosent work re install windows
I got the same error in my Dell Inspiron 14 3000series. I did the steps above but in reverse. When I opened up bios setup, secure boot is already disabled.So I enabled it. Advanced boot is on Legacy so I switched it to uefi. Then I saved and exit and it loaded Win 10 like it normally would.
Genecis mejia-perez crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 12,474
