Mac mini does not turn on after upgrade
Hi everyone, yesterday I did upgrade my macmini late 2014. I installed a 500GB SSD samsung.
Once the mac has been restored no longer signs of life. The fan rotates for 1 second and then stops.
Can anyone help me?
Thank you
Which Samsung drive did you put in the 2.5 or the M.2?
2.5 evo 850 500gb
Carefully pop off the bottom cover and disconnect the 2.5" SATA SSD are you able to get the Apple logo with the blinking question mark?
Not by signs of life. Only the fan rotates for 1 second and then stops. But I did not try to start it without HD, can you do it?
Non ti seguo qui. Il sistema non risponde quando si disconnette la SSD? Se è così, dovrai aprire il sistema in modo che sia stato danneggiato o non riuscito a ricollegare qualcosa.
Not following you here. Is the system not responding when you disconnect the SSD? If that is the case you'll need to open the system back up as you either damaged something or failed to reconnect something.
Il sistema non si accende neanche. Una volta rimontato e collegato alla corrente, il mac mini non da segni di vita. L'ho smontato mille volte, nessun componente è danneggiato, tutti i connettori sono collegati. Neanche se inserisco il vecchi HD mi da segni di vita
The system does not turn on either. Once reinstalled and connected to the current, the mac mini does not show signs of life. I removed it a thousand times, no component is damaged, all the connectors are connected. Not even if I insert the old HDs as a sign of life
If you don't get the POST chime then it's likely something hardware related. Sounds like the power supply is shutting down. Check all connections, especially the SSD.
all connections its ok
I would disconnect as much as I could from the motherboard (drives and peripherals). If it still won't do the POST then it's likely a bad motherboard or power supply. This type of power supply shuts down if the load is open or shorted.
umberto crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 218
