What optical drive do I order
I need to replace the optical drive in my iMac Intel Core duo but there are several choices. I bought the computer new in 2008. Which should I get. I don't want to take the whole thing apart just to find out.
crwdns2889612:0crwdne2889612:0 -1
Pretty much any superdrive with the same housing dimensions will do. I have replaced them with other G5 superdrives heck I have even used one from an iBook G4. Just make sure you get one with your needs for example if you want to be able to burn dual layer disks and the speed of the superdrive, they don't all have the same capabilities. You will have to use the old connector board, optical drive bracket and EMI gaskets as well as the temperature sensor on your new drive. Here is the guide for replacement: iMac Intel 17" Optical Drive Replacement
I hope this helps.
Edward Heins crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 829
