Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Cable 2 I-Phone 3g
I recently replaced the front cover on my iphone and all went well until it came to reconnecting the cables. Cable no. 2 wont click into place and Im afraid to force it - any suggestions? The other two cables are grand.
Update
The only part I replaced was the glass as it was cracked. The cables are all the originals - cable two just wont click into place, the other two click in fine - I put it together last night without being able to connect the Cable No.2 and all that happened was it showed me a picture of the battery needing charged. The home button appears to not be working either, there isnt that little click that you normally feel when you press the button. I think I am going to have to take it to an expert.
crwdns2889612:0crwdne2889612:0 -1
crwdns2944067:05crwdne2944067:0
Geraldine, just wondering if you have a 3G part or a 3GS part. I know you say your phone is 3G just to let you know that the 3GS part does not fit. If you can verify it, we can help you find an answer.
my phone is a 3g and the glass cover i order is for a 3g. Any help you could give me would be very much appreciated.
My phone is a 3g
would you be able to take very detailed picture of the part you have put in the phone? especially the connector part of it. the best, if it could be picture made using makro on your camera
would be nice to get a picture of it. However, try to check the plastic parts on the board with a magnifying glass and look at the cable coming from the digitizer.See if you have any bend pins or damage to the plastic. Also it does not fit because it binds, goes in crooked does not go in at all?
If you look on the connector ribbon itself there is a part number, I can't remember what number goes with which but I had the exact same problem when I replaced mine, I was sent a 3GS part when I ordered a 3G part, took me a while to figure out where I was going wrong.
Don't take the fact that you have ordered a certain part at face value.
Hey Wayne
You are super. I just checked my order with Amazon and I was sent a part for the 3gs - i have reordered now for the 3g and hopefully this will work. Ill let you know. Thanks for all the advice
Geraldine crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,642
