Released in 2007, model F130W. Available with 512MB or 1GB internal memory.
How do I fix a coroded battery pack?
How do I fix a coroded camera battery pack
@shejskaw, Sheila, If it is the battery pack it self that is corroding, consider replacing it as it could be damaged/leaking, perhaps do a search using your model# for replacement. You can use the link below to open/access the battery compartment/contacts and give them a good cleaning. The eraser end of the ink pen is slightly abrasive and works well, scrub it across the battery contacts, a little work and patience and you should be able to remove the corrosion. blow or gently shake out any eraser shavings. Qtip/soft cloth dampened with 90%+ Isopropyl Alcohol will also work to clean terminals of corrosion. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Disassembling Flip Video Outer Shell
Sheila Whale crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 324
