The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Unable to turn on Wifi but data still working
Everything was fine this morning. Dunno why suddenly im unable to connect to wifi.
It's like this, the wifi button cannot be turned on, the color is darken. I still can turn it off, but when i tried to turn it on, the button ust darken but nothing happen, however my data still works,please help.
Try installing an app called "WiFi manager" from the play store. If that doesn't fix it, a factory reset should, and as a last resort, check your wifi antenna. If all else fails, it must be at the chip level, which requires replacement of the motherboard. Hope this helps!
After installing the apk version of the software you've mention, I've clicked on the "turn on wifi" but its not working, the wifi button(in where i scroll down the screen) is still dark yellowish color(just like when you turn it on, it takes time before it fully turn yellow, but in my case it automatically turn off before it turn yellow), im now going to try the factory reset method, wish me good luck.
Btw, this is the first time using this website, thanks for fast responds:)
Your welcome. We always try to provide the best answers as fast as possible. If the factory reset doesn't fix it there is a good chance it's just a loose wifi antenna.
Apparently I still cant turn on the wifi after formatting, is this consider as hardware failure?
Possibly. It is very likely now that the wifi antenna is loose. Especially if you dropped it recently. Use the guide below to check it. It's the blue cable on the left of the phone. Samsung Galaxy Note 3 Motherboard Replacement
Also look at this guide:
Samsung GALAXY Note 3 - Service / Test menu
Open the phone app and dial the 2nd and 3rd to last codes and find any wifi related options.
Navinous crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 134
