The Sony GTK-XB5 is a high powered home audio system with Bluetooth that was released in 2016. This audio system is available in black, red, and blue.
Is it possible to add a battery
is it possible to add a battery?
There is now the XB60 and XB90 with in built battery
becki2000seb besides all the sarcasm here is a short answer. No. The power requirements for your Sony GTK-XB5 are to large for a battery.
Apologies if it was taken as a sarcastic answer. I am used to carrying around external batteries. They even make them for laptops. A first generation HyperJuice was a literal brick.
https://www.hypershop.com/products/hyper...
crwdns2947721:0crwdne2947721:0
The power consumption of your battery is 30w.
You need something of massive capacity, something like this:
https://www.amazon.com/Portable-Generato...
I don't know why this is funny, but it is.
True. I wish I could put an inbuilt battery some how
some bike battery could work?
I like reviving olde threads, especially ones with no decent answer! I found lithium scooter battery packs with built in BMS charging circuits integrated on Ebay. Wire in a charger for when the thing’s plugged in and you’re solid, long as you can also convert the electricity inside to amp the board, also :)
I used a 36 volt 2.6Ah battery for mine after the power supply in it die and it works great.
I use a 36 volt Ryobi power tool battery because the power supply in it died.
yes iam pretty sure u can go to canadian tire and buy a jump start make sure it has a ac outlet...easy it should work good how long not sure.
becki2000seb crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 9,192
