Is it possible to add a battery
is it possible to add a battery?
becki2000seb besides all the sarcasm here is a short answer. No. The power requirements for your Sony GTK-XB5 are to large for a battery.
Apologies if it was taken as a sarcastic answer. I am used to carrying around external batteries. They even make them for laptops. A first generation HyperJuice was a literal brick.
crwdns2947821:0crwdne2947821:0
The power consumption of your battery is 30w.
You need something of massive capacity, something like this:
I don't know why this is funny, but it is.
True. I wish I could put an inbuilt battery some how
some bike battery could work?
I like reviving olde threads, especially ones with no decent answer! I found lithium scooter battery packs with built in BMS charging circuits integrated on Ebay. Wire in a charger for when the thing’s plugged in and you’re solid, long as you can also convert the electricity inside to amp the board, also :)
I used a 36 volt 2.6Ah battery for mine after the power supply in it die and it works great.
I use a 36 volt Ryobi power tool battery because the power supply in it died.
yes iam pretty sure u can go to canadian tire and buy a jump start make sure it has a ac outlet...easy it should work good how long not sure.
crwdns2942667:0crwdne2942667:0 9,214
There is now the XB60 and XB90 with in built battery
crwdns2934271:0crwdnd2934271:0 Dedbny crwdne2934271:0
