Speakers are not working at all
Internal drive crashed and now I'm using an external hard disk. Still speaker is not working.
I would recommend fixing the internal drive issue first.
This model comes with a custom blade SSD. Here's the IFIXIT guide to gain access to it: MacBook Air 11" Early 2014 SSD Replacement. IFIXIT sells Apple SSD units but you can use a 3rd party SSD which will be a bit cheaper for the larger sizes. Here's the info for OWC: SSD Flash Storage Options For Your Mac
In any case once you have the new drive installed you can then do an Internet recovery. Here's more on that: About macOS Recovery & How to reinstall macOS.
Once you get the OS installed and any needed updates see if you still have the problem.
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 264
crwdns2944067:04crwdne2944067:0
Did you get your system wet or bang it?
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
Yeah i think i got it wet but I am not sure
crwdns2934271:0crwdnd2934271:0 its nippon crwdne2934271:0
You'l need to open the system up and do a full inspection of the logic board for any corrosion (both sides). That could explain why your drive and speakers died. May need a new logic board.
Check the I/O cable pins on both side (cable which runs over fan). If it is saying no output audio devices in the settings, this will most likely be the cause. SSD failures are rare on the 2014 models, so liquid damage could be the cause of this problem.
crwdns2934271:0crwdnd2934271:0 Reece crwdne2934271:0
