The 2012 should have come with a
Standard AirPort: 802.11a/b/g/n
802.11a/b/g/n Standard Bluetooth: 2.1+EDR
My 2009 MacPro has a:
AirPort Extreme (0x14E4, 0x8E)
Firmware Version: Broadcom BCM43xx 1.0 (5.106.98.100.24)
Check to see if it's just not plugged in. (the wires are pictured on the MacRumors link below) inside the plastic panel.
How Does AirDrop Work?
To use AirDrop, both Bluetooth and Wi-Fi must be turned on. AirDrop uses Bluetooth to locate other AirDrop-enabled devices nearby and uses the faster Wi-Fi network to transfer the files. Because AirDrop uses Bluetooth, it adheres to a common Bluetooth range, which requires devices to be within 33 feet/10 meters of each other.
When AirDrop is enabled, it triggers Bluetooth to look for other AirDrop-enabled iOS devices that are in the area. This process is similar to pairing your iPhone with your car’s Bluetooth system. The devices “advertise” that they are open for business, and if they are within range of each other, then they start the connection process. Once the connection is made, a simple device-to-device Wi-Fi link, called Wi-Fi Direct, is created between the two. The Wi-Fi Direct link can be created even if you are in the middle of nowhere, without a Wi-Fi network. So, you get the fast file transfer speed of Wi-Fi without a router or an internet connection.
Here's some great info on doing the upgrade:
https://forums.macrumors.com/threads/802...
Personally I have not upgraded mine because I am using a hardwired Apple Airport Extreme Router A1521 802.11 ac, so I don't need one for my Apple TVs.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
6
crwdns2944067:04crwdne2944067:0
The actual bluetooth works fine, I've been using my bluetooth headphones with it fine. I think it's just the wrong firmware. The advert said "Bluetooth 2.1 + Enhanced Data Rate" and the firmware says "v208 c518" but I think I need a newer chip like your "BCM43xx 1.0" - as I said it was refurbished and I suppose it had a general bluetooth chip put in rather than one that necessarily worked with the more modern AirDrop standard.
Presumably I need to buy a new bluetooth/wireless chip and install it, at least I can eBay the existing one though. If there's any ideas for a specific card or ebay/etc links then that would be great.
crwdns2934271:0crwdnd2934271:0 Calvin Graham crwdne2934271:0
@danj knows more about these than I do.
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
Sadly, the older Mac Pro's don't offer the needed Airport card for Hand Off services : Use Continuity to connect your Mac, iPhone, iPad, iPod touch, and Apple Watch & System requirements for Continuity on Mac, iPhone, iPad, iPod touch, and Apple Watch
But AirDrop services are supported! Use AirDrop to send content from your Mac
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
I upgraded a 2008 Mac Pro (sierra) with a tiny BCM94360cdax card and HandOff is supported and Airdrop. You have to connect 3 wifi antennas to J0, J2, J3 and Bluetooth antenna to J1. Don't forget to reboot twice to enable Apple bluetooth drivers
crwdns2934271:0crwdnd2934271:0 Comité de quartier Ouest crwdne2934271:0
