Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
Batteries interchangeable between series?
Are Apple watch batteries interchangeable between all the different series? Say I need to replace a 38mm apple watch battery (original), can I use a 38mm battery for series 1 in the original?
Can I use the Apple Watch battery from a series 1 for a series 2
Hi,
Is the apple watch series 1 and series 2 batteries interchangeable ?
Sorry no, The original Apple watch uses a different connector system for most everything and that includes the battery. See for your self here:
Original Battery
Series 1 & 2 Battery
**Editing to say that I am 100% sure you can swap batteries between the First Gen and Series 1 Apple watches because I’ve successfully done it countless times.**
I'm pretty confident that you can use a battery from a Series 1 Watch in an Original Apple Watch. The internals between the Original and the newer Series 1 are almost identical. (The processor was about the only change.) In fact, if you order a replacement battery from ifixit.com, the batteries are listed as being compatible with either Watch. Also, the details about the used OEM batteries listing even says that they are taken from either an Original or a Series 1 Watch.
Apple Watch (38 mm, Original & Series 1) Battery
crwdns2937315:0IF308-010crwdne2937315:0
Series 2 is different though and cannot be used in the earlier models.
crwdns2886500:0Replace a 205 mAh battery compatible with Apple Watch 38 mm Original and Series 1 Models A1553 and A1802. 3.8 Volts (V). Battery Model A1578.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$16.99
Sheila Smith crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,730
