The Hoover Carpet Basics Power Scrub Deluxe Power Cleaner can be identified by its model number: FH50150. This upright power cleaner was originally released in 2014.
hoover power scrub carpet cleaner FH 50150 will not start
hoover carpet cleaner,FH 50150, just stopped in the middle of cleaning. waited and waited, still won't start. Purchased new power switch fuse. Still will not work. Of course it's off of warranty by a few months. What can I do now, besides screaming!
crwdns2889612:0crwdne2889612:0 11
crwdns2944067:026crwdne2944067:0
It was off warranty, I only had it a little over a year, but decided to just give Kohl's a call. No questions asked, I was able to take it back for full refund or replacement. I went for replacement. I would have certainly used your ideas! Thanks for the inputs!
lucky you, i purchased a hoover power scrub elite 7 months ago online from hsn they wont help me i contacted hoover but havnt heard anything from them so dissapointed only used it once the brushes quit working and wont suck and yes i know about putting the dirty water tank in correctly, the only thing the dumb thing will to now is blow its heat. im so disscusted
how do you replace the fuse
the thing to turn it on wont start the machine, it just quit
Mine just stopped turning on too! Seems to be a common problem with this model. Also the leaking of water and sporadic working altogether. Company should offer compensation!!!
crwdns2934275:021crwdne2934275:0
crwdns2933315:08crwdne2933315:0
@jesada ,linda b. If still under warranty, have repaired/replaced/refund under warranty. Did a search for a service/repair manual with no luck. All I can suggest is to disassemble the vacuum to access motor connections and carefully test there with DVOM for power when switch on. If power is present at the motor and motor not running, would signify motor faulty. If no power present at motor you will have to trace back through wire harness in search of bad/damagedwire/plug/relay/fuse/switch. Links below may help, the 1st link is a exploded parts view of your vacuum and 2nd link is owners manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.partswarehouse.com/FH50150-H...
https://hoover.com/file/2123/,%20http:/h...
Hi,
A safer way to do it it to use an Ohmmeter. (an Ohmmeter is a meter, which measures resistance it is a function provided in a DMM (Digital Multimeter. You can get an adequate one from most larger hardware stores for about $10).
Place the meter's two test leads. across the vacuum cleaner's power cord plug's two pins (with it disconnected from the wall outlet of course) and turn on the vacuum ON switch. There should be a reading on the meter. If not, disassemble the cleaner where the cord enters it and the test both wires from the plug to where they are connected using the Ohmmeter. If faulty replace the cord or the plug. If OK trace the wires using the Ohmmeter through the cleaner as per answer above until you find the problem.
it is not a vacuum cleaner is a shampoer.
Where did you find the power switch? I’ve had mine completely apart and cannot find it. I got the power switch but not the fuse.
Dec 2019
My Hoover F5915-905 Spin Scrub 50 carpet conked out without so much as a whimper. Got the multi-meter out and confirmed it wasn’t the switch or motor winding. The problem turned out to be a 128C thermal fuse mounted on the motor behind a black plastic sleeve. Fixed it for $2.50.
crwdns2889612:0crwdne2889612:0 9
crwdns2944067:08crwdne2944067:0:
How did you replace the 128C therm fuse? Where is it located?
The photo above shows the fuse next to my thumb on the motor. You need to do a lot of disassembly to get to the motor. Take care to mark where each screw was removed because they are all different lengths and sizes. Follow the motor windings to the fuse which is wrapped in a black rubber cover. I cut the old fuse with wire cutters then crimped the new fuse using the connector provided with the new fuse.
I had the same exact issue, thanks for posting your solution.
Where did u purchase the fuse
I uploaded a picture of the fuse that I purchased. This is a common item at any electronics store or online.
Took mine into a local vacuum repair/parts store. $15 to check it out. Definitely better than mucking around with it for hours myself, likely ordering parts that don’t fix it, and THEN taking it in to be checked out.
Is there any way to by pass that thermal fuse.
I think its more trouble than its worth!
I am SOOO sick of cheap ass appliances. I am in my 60s, from an era when things lasted forever, almost. Because obviously I now own a cheap ass Hoover!!
@Heather Dionne i am 81 and i agree 100% with you.
I am 80 yrs and can’t agree you more these machines are junk made in China. Mine was 3 months old when it quit.
Total junk! My Hoover had been used one time, then my husband died and I am just now trying to use it again for the first time, 14 months later. Of course the warranty is gone. It came on, then died and will not come on again. I will never, EVER buy another Hoover product again. I am 75 yrs old and refuse to pay through the nose for inferior products.
I agree will never buy hoover they are junk and hoover does nothing to help out😡
A common problem with many appliances that will shut it down are the push on spade lugs that are used. They loosen up and create a bad connection that heats up and burns causing it to totally disconnect. Generally at the power switch. This requires replacement of the switch, spade lugs and maybe some wire. If you are lucky, just the spade lug.
Is their a reset anywhere on the cleaner I have used it 3 times and will not come on and yes it’s out of the warranty guidelines
just about to lug my hoover rug cleaner out to the garbage., because that's what it is garbage. such a game being played . so you buy an appliance & now have to pay enormous amts. to warrant it. and if you don't choose to do this,it will give out shortly. wake up people. make them in the usa.
Made in Germany or Japan, better choice better life.
I bought my Hoover Powerdash Pet less than a year ago. I only used it ONE time and it worked pretty good. I tried to clean my carpet the other day (only the second time ever used). I have a small carpeted area in my home. Half way thru cleaning my carpet, it started making a horrible noise and started smoking and then just quit. It will not turn on and I'm now stuck with a half clean/half dirty carpet!!!
So listen up yall I got a work around depending on where you bought your hover. I swear by their cleaning power but their products brake down way too soon so I just go buy another one clean up my used one really good switch the stickers and take it back for a full refund. Easy peezy
I bought mine, but didn't use it right away. When I did, it turned on for less than 5 seconds. The seller (Walmart.com 3rd party) said to go through Hoover. Hubby got very sick, and clean carpets flew to the bottom of my list. Once I got with Hoover, they said, "too bad, out of warranty."
there is nothing to do now but troubleshoot it and hope it is something simple and cheap to fix. Start with getting a multimeter. Harbor Freight has them cheap. You will have to open it up. A youTube video will probably help. Then trace the wiring with the meter till you find an open. If it ran for only 5 seconds it could be just a loose connection, bad switch or defective thermal fuse. HOWEVER, If the fuse is open it could be something more serious like a shorted motor the blew the thermal fuse. Good luck.
Just go buy a new one yall, clean your old one up really good, switch the stickers that are located on the back of the cleaner with the serial number on it and put it back in the box then return it from where you got it for a full refund. So now you've replaced your hover for free. Simple. I suggest staying away from Walmart tho. Try home depot or Lowes
linda b. crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 67
crwdns2936753:030crwdne2936753:0 306
crwdns2942667:0crwdne2942667:0 94,230
