How to repair unresponsive "Enter" key?
On my Apple wireless keyboard, the "Enter/Return" button randomly stopped working. Is there any way to repair the key?
I would see if a cotton swab that is just moist (not dripping wet) with 85% isopropyl alcohol can clean the crud around the key as it just could be getting stuck. You may need to go a bit deeper here by carefully lift the keycap to get under the key to do additional cleaning as gunk could be effecting the scissor mechanism as well underneath.
If that doesn't fix it see if the batteries leaked as the chemicals in the batteries could have damaged the conductive traces.
Sadly, these keyboard are not very serviceable. Here is the IFIXIT teardown: Apple Wireless Keyboard (A1255) Teardown. Jump down to Step15 to see how to pop the keycap.
Is there any way I can make the "return" key act as an "enter" key so i don't have to keep using the mouse to press enter? Or do I have to download something ??
ur a moron, u have reached maximum stupidity
You can only do that by replacing all the keyboard keys, where you need to be well experienced to perform the operation since there is head involved and if not well done you end up frying the chassis. The best option will be to replace with a new keyboard. If this is helpful, do not forget to mark.Tx
I don't think you need to go that far ;-}
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 85,207
crwdns2944067:04crwdne2944067:0
Need help too! Can't type because the return/enter key won't work. Please help
crwdns2934271:0crwdnd2934271:0 Rosa Espinoza crwdne2934271:0
Did you try cleaning the pads as I explained? The newer versions of the keyboard are now sealed so you'll need to replace it (not repairable)
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
My return/enter stops working and while I was searching find a not perfect but good enough solution. At least I can use it till I will buy a new keyboard. So there is a software karabiner https://pqrs.org/osx/karabiner/ at the link and you can change any key to any key (Remap) by using it. So I replace eject key (which I never use) to enter key. It is working with the latest OS Mojave.
you can change any of your keys to any key for example you can change right shift to return key either.
crwdns2934271:0crwdnd2934271:0 Übeyd Söylemezoğlu crwdne2934271:0
@ubeyds that worked for me! Thanks for taking the time to help :)
crwdns2934271:0crwdnd2934271:0 Rebeckah Turbett crwdne2934271:0
