Upgrading the WiFi/Bluetooth board MacBook Air Late 2010...
Hi Guys,
Are there any 3rd party cards that will fit my MacBook Air, to give me 802.11ac and Bluetooth 4?
Or would this fit?
MacBook Air (Mid 2013-2017) AirPort/Bluetooth Board
Thanks...
crwdns2886500:0Replace a 802.11ac AirPort wireless / Bluetooth 4.0 internal card compatible with the A1465 and A1466 model Mid 2013 to 2017 MacBook Air laptop. Part #661-7465, 653-0020, 653-0023.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$49.99
Yes, the board you linked to will fit and work.
But... you won't get the full WiFi speed bump you maybe expecting. The air's use a single antenna design while the MacBok Pro's use a dual or tri antenna design gives them the ability to get MIMO services.
As for BT4.0 you'll get that but I'm not sure if hand-off services will work correctly.
In the past i'd done a similar trick to get better wi-fi in another mac. I recall buying the wifi/bluetooth module for a G5 or MacPro and installing that in a MacBook to get the 802.11 N setup that wasn't a part of that current generation. What i'd do is take a look at the configuration of the card you have currently in the computer. It could be useful to take out the unit you have and take a good picture then re-install and compare your photo to that of the one you're looking at. The software is all included as a part of the macOS so drivers aren't an issue for most cases.
Count the number of pins you can see and compare the notches for the screw and the slot. If they match up its pretty reasonable that it would work.
A very major word of caution. If there is a voltage issue on the card, either requiring too much or needing much less power there is a risk of causing damage to the card, slot, or main logic board of your system.
The final note is that in the cases of people doing things like this you may notice additional antennas on the replacement that you won't have in your system. It could affect performance of certain bands of wi-fi/bluetooth so be aware that you might the upgraded functionality, but you may also have poor performance unless you can figure out an antenna solution (or it will work fine, you won't know till you try).
Good Luck!
There's a guide for this online: MacBook Air 13" Late 2010 AirPort/Bluetooth Card Replacement
iFixit keeps deleting my helpful comments on this as spam for no apparent reason so I will simply say: you need MHF4 antenna extensions.
David Jones crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,647
