The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
tail lights no work
Hi! I have a problem on my 2004 Jeep Grand Cherokee.
the tail and license plate lights do not work, but the brake , directional back-up, and the hazard lights are working normally
Can You please help me to fix. my problem
and I also want to know where is the fuse of the tail lights
THANKS!
are your front lights working or are they dark as well . There on the same fuse. If your front makeres are working then theres probably a break in the wire to the rear
I have power to my driver side rear lights all of them but I dont have anything on the passenger side all of a sudden. None of them work. All the bulbs are good. Any help would be greatly appreciated and all was working fine and then boom
The fuse panel is located by the drivers left knee under the dash.
https://w05.dealerconnect.chrysler.com/s...
Hope this helps
your owners manual should have a breakdown of which fuse is which. if not use a multi meter to find the blown fuse
@chuyin ,Jesus Contreras , If after checking all fuses and bulb's and does not rectify the issue, check the bulb sockets them selves for corrosion, burnt, contacts may need pried up a bit(little) to enable grounding or power to the bulb, (this is a common issue) if contacts broke or badly burnt, replace the socket. Below are a couple links that may help. Good luck.
https://www.youtube.com/watch?v=BACokV7G...
http://repairpal.com/electrical-contacts...
I was able to fix my son's 2004 Cherokee by switching sockets -- the tail/brake socket fits in the back-up socket and also the turn signal socket.
Jesus Contreras crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 73
crwdns2942667:0crwdne2942667:0 24,433
