Released alongside the AirPort Extreme base station, this hard drive equipped variant offers 802.11ac speed on a time capsule NAS.
Time Capsule not powering on
I've been using this device for about 1 year until one day I found the light blinking amber. The Airport app was reporting the device was overheated. I pulled the plug and waited for it to cool down and when I plugged it back in there was no light at all. All I could hear was the noise of HDD spin up and nothing seemed to work.
It's out of warranty so can't take it to apple.
I cracked it open and found out that the PSU seemed to be functional. I checked the output voltage and it was a solid 12 Volts. But the fan doesn't run at all. I even tried to apply voltage to the fan to see if it runs but it didn't.
I checked the fan socket on the mainboard and 12 Volts appeared on the multi-meter.
Can I be sure that the fan is faulty? Because I don't want waste money on a PSU to find out it was not necessary.
BTW can someone verify that a working TC acts like mine when no fan is connected.
Thank you
crwdns2944067:010crwdne2944067:0
@shoeib hey bro, did you find a solution?
@ironjer - I'm sure a new fan fixed the cooling issue
@jesus no man. I eventually came to the conclusion that the logic board is fried.
@shoeib maybe a bake... mine TC no fan spinning and no front light either but, the hard disk power on. I don't want waste money in new PS. :(
@danj I have no front light and no fan spinning, just the HDD works. Maybe the Logic Board is failing...
crwdns2934275:05crwdne2934275:0
More likely the fan died here. For about $20 US you should be able to find one.
I don't have a A1470 TC right now but I've had to replace quite a few fan units across the entire line of TC's
Do you by any chance remember how the TC acts with a faulty fan?
Thank you
@danj would TG Pro read this?
@mayer - TG Pro won't work here. It only works under OS-X or MacOS. The TC's use a custom file system and its own OS. AirPort Utility will report if the unit is overheating.
crwdns2947515:0crwdne2947515:0
See if any of the following articles can help:
shoeib crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,890
