automatic shut off failure
The kettle doesn't shut off when it reaches boil. Is there any way to repair?
Your thermostat has failed. It appears Delong does not sell the part. http://www.ereplacementparts.com/delongh...
You could try taking the bottom off and see if it can be opened. Then post a couple of pictures and we can see if we can suggest a repair.
Is the sieve missing ? Or is it broken ?
Most cookers are switching off by “enough" steam.
If the steam can leave the cooker too fast, they won't switch off immediately
They switch off quite delayed.
Try to get a new sieve.
To test, if this reflect's your case - you can test by carefully “blocking" the exhaust e.g. wiping cloth. But carefull - it get's hot !
@cs_htw oh brother. IT's a kettle not a cooker! No sieve! No steam! Just a nice continuous boil. You got the wrong device
That is exactly what it was! I searched and searched, found it and voila! Thanks!
yes, the sieve was missing ( it was buried in the box ) and when discovered and installed ( after much figdeting with the bendable prongs to make it fit snugly ) , the unit shut off as designed . i would note also that, in my opinion, the water level must be above the sensor protruding from the thermostat.
He meant the filter by the spout, not the sieve if it let's steam our it won't switch off. I found that ours must have come out, and that's what was wrong. All fine now.
I would never in a million years have beleived that simply replacing the deteriated screen on the spout would have fixed a very6 frustrating problem of my Salton Kettle refusing to shut off!! Unreal~ Thanks a ton for this effective fix!
I’ve just had the same issue on a Hario Electric Buono kettle. I took it apart and realized that the bimetallic thermostat had rust on it, preventing it to do its work and “snap” when the steam reached it.
It’s a little disk made up of two different types of metals that changes shape with heat. In my case, the fix was easy: I used a metal brush to clean it up and it corrected the issue. It could be work taking a look at your kettle to see whether it could be the same issue.
It relies on steam pressure to operate the cutoff switch, so any gaps around the filter in the spout will prevent it from working. Take out the filter and clean off any limescale around its edge and on the inside of the spout where it sits to improve the seal. It's essential that it clicks correctly into position - quite fiddly to get right.
PS. With age, the filter can weaken and crack to cause the same problem,
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 227
crwdns2959996:0crwdne2959996:0 50,429
crwdns2944067:08crwdne2944067:0
Please give us a make and model number.
crwdns2957956:0crwdnd2957956:0 mayer crwdne2957956:0 crwdns2950251:0crwdne2950251:0
I have this problem too. The make & model is Delonghi - KBX3016
crwdns2957956:0crwdnd2957956:0 Lee Hayes crwdne2957956:0 crwdns2950251:0crwdne2950251:0
The steam switch is not operating.
either the steam switch is broken or the hose is blocked (small hole or pipe inside kettle which leads to steam switch. It operates when enough steam pressure goes down pipe or small hole) can also be the lid not shut properly.
crwdns2957956:0crwdnd2957956:0 St jim crwdne2957956:0 crwdns2950251:0crwdne2950251:0
I think, a sketch or photo, how a steam pipe typically looks like might be very helpful - to identify the actual one in any water cooker.
crwdns2957956:0crwdnd2957956:0 CS.Singen crwdne2957956:0 crwdns2950251:0crwdne2950251:0
I had this issue. after reading these comments I realized that the screen/filter on the spout of the kettle was missing. I covered the spout with a spoon and then the automatic cut-off started working again.
crwdns2957956:0crwdnd2957956:0 Jared Menard crwdne2957956:0 crwdns2950251:0crwdne2950251:0
