Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
OnePlus One wifi chipset replacement
I was wondering if the oneplus one Qualcom chipset could be removed from the motherboard and replaced with another manufacturer chipset. I know that is it likely laminated to the board. Is it still possible to remove the chip? Even with moderate difficultly. Also I was wondering if anyone had the pin outs for the chip? I love the phone but could really use another chipset as I don't want to run an external wifi via the USB.
As you can see in this link the Wifi chip is rather small. I would call difficult to extremely difficult to solder of the chip and change it.
OnePlus One Teardown
It should be easier to perhaps fins a used motherboard and change that.
But you could also look at the Oneplus forum
https://forums.oneplus.net/forums/tech-s...
I'm looking to replace the wifi chip with a different manufacturer. Specifically RealTek. I'm looking for a wifi chip that can be placed into monitor mode in order to assist in wifi troubleshooting without having to lug around my laptop or using an external usb wifi. I will be running a linux distro on the OnePlus with the RealTek firmware already installed.
To install another wifi chipset sounds very difficult since the pin layout would have to be the same.
Wes Mongold crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,444
