You're seeing the default setup of the drive. Its been awhile since I've put one in if I remember correctly you need to erase and re-prep the drive.
Restart your system and go into Internet recovery (left Command, Option & R keys), or you can boot up under an external USB drive. Press the Option key to get to into Boot Manager.
Then once booted, go to Utilities, Terminal, within Terminal type the following:
diskutil unmountdisk disk0
gpt destroy /dev/disk0
Close Terminal. Open Disk Utility select the Aura drive on the left pane and erase it and reformat the disk, re-install the OS again and migrate your stuff back over. That should do it.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
4
Go into 'About This Mac' then select 'System Report' Please take a screen shot of the 'Storage' window, then take a shot of NVMExpress window (you may need to slide the slide up a bit to get all of the info).
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
Storage
Macintosh HD:
Available: 377.06 GB (377'057'767'424 bytes)
Capacity: 479.09 GB (479'087'239'168 bytes)
Mount Point: /
File System: Journaled HFS+
Writable: Yes
Ignore Ownership: No
BSD Name: disk0s2
Volume UUID: 6AFFB95B-A125-39A4-A1DE-ECE58F24158A
Physical Drive:
Device Name: OWC Aura SSD
Media Name: OWC Aura SSD Media
Medium Type: Rotational
Protocol: PCI
Internal: No
Partition Map Type: GPT (GUID Partition Table)
NVMExpress
This computer doesn't contain any NVMExpress devices. If you installed NVMExpress devices, make sure they are connected properly and powered on.
crwdns2934271:0crwdnd2934271:0 JerSta crwdne2934271:0
