Trackpad unresponsive on half of trackpad
I recently replaced the keyboard, battery and trackpad on a macbook pro 15" mid-2009 unibody. The keyboard and battery work fine, but I am finding issues with the track pad.
The trackpad is able to click, but it is unresponsive to mouse movement in the upper half of the trackpad. I can only move it left and right if I use the upper half of the trackpad. I am able move the cursor in any direction on the lower half.
I have tried adjusting the main clicker screw, but I don't belief that to be the issue because it's able to click anywhere on the trackpad just fine.
The mounting screws are tight in their place.
I think I received a bad part, but I want to explore all the options before returning the part.
I replaced the cable with a spare, same issue. I believe it's either a bad part or the logic board itself is somehow damaged. Thank you for your answer!
The click plate adjustment only effects the click function nothing more.
Sounds like you got a bad part or the connection to the logic board is having problems. Inspect the ribbon cabe to make sure there is no damage (tear) and the connection is firmly seated.
battaninic crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 4,506
