The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
When door closed is not booting and you cant hear the chime
But when the door is open and laid flat.It will boot and you can hear the chime and you will see the startup icon.
I checked all the power supply cables and HD cables , But are all fine.
Is there a switch some where ? I thought it was the other way around ...Meaning when the door is open should not boot
and when door closed should
Please help.
Thanks,
Peymon Gorkani
crwdns2889612:0crwdne2889612:0 -1
There is no door opened or closed switch. It should boot either way. Lay it on its left side and try starting then open the door and try. Please tell us the results. Also, when not starting do you get a light on the power button or any sounds or other lights?
a good start +
Ok , No Chime sound when not booting , But yes the Switch light will blink and the light on Cinema 17 inch switch also lights on , But no display...
Ok I found the problem...There are 4 Holding screw sockets under the processor Board (Remove Heathsink then the board) Those were very loose and almost of the plate , Tighten those and reassembled and all is well now...Thanks
Glad your problem got solved.
Peymon crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 833
