The Acer Iconia Tab 8 A1-840 is an 8" Android wi-fi tablet with 16GB of flash memory and 2GB of RAM. Acer released the Iconia Tab 8 A1-840 in 2014.
Tablet works but screen is black
My tablet is working I can hear my music playing through my head phones. But the screen stays black when I press the power button I can barely see the screen light up showing that it is on. Help please. Before the screen went black it was glitching out
If your screen isn't broken it may just be a loose connection, I assume that it is built the same way as the A1-830 so you should be able to pry the back off and check the connection. If this doesn't work then you will likely need a new screen to test/replace the current one.
It doesn't display. It just lights up. When i turn it on it turns on it vibrates but the acer logo doesn't show up nothing shows up except the light up. If you can find a video on how to take the back off
Ashana, The link below is for trouble shooting your device, hope it helps. Good luck.
You can also do a google search using your devices info to see how to remove back to check connections as Hortman recommends. I hope this helped you out, if so let me know by pressing the helpful button.
Acer Iconia Tab 8 A1-840 Troubleshooting
I can't find video. If you can please link it
Ashana Frank, here are vids. showing Acer Iconia A1-810 Screen Replacement - Resassembly, I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=I18JtQXD...
https://www.youtube.com/watch?v=eNb4eSZT...
Mine is iconia w 810 its full charge if you turn it on the acer logo will come out then it will be gone and the light will remain until the battery drain then i will charge again if i turn it on same thing happen repeatedly any help in this case
Ashana Frank crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 7,477
